Продан Specialized Epic Marathon L (2013)
Phone: +7 960 l38-86-58
Сообщение Anton_Grey »
Продаю Specialized Epic Marathon "L", пробег около 1000 км. Цена 115т.р. Куплен в Москве Магазин "Велоцентр", документы. Косметическое состояние 4+. Продаю в связи травмой. ТОРГ. Можно приехать посмотреть. Больше фото по запросу.
РАМА FACT 10m carbon front triangle, 29" geometry, FACT IS construction, gussetless TT (S/M), carbon seatstays, M5 chainstays, tapered HT, carbon PF30 BB, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 100mm travel
АМОРТИЗАТОР FOX/Specialized remote Mini-Brain w/ AUTOSAG, inertia valve, Brain Fade adjust, 187x47mm
ВИЛКА Custom RockShox SID 29 Brain, inertia valve damper, air spring, tapered alloy steerer, top-mount Brain Fade and rebound adj., QR, 100mm travel
РУЛЕВАЯ 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
ВЫНОС Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, 6-degree rise
РУЛЬ S-Works XC Carbon flat bar, uni-directional carbon, 680mm wide, 8-degree backsweep, 31.8mm
ГРИПСЫ Twist grip
ПЕРЕДНИЙ ТОРМОЗ Magura MT6, hydraulic disc, Hi Friction pad, alloy caliper, Storm SL rotor, S/M: 160mm L/XL: 180mm rotor
ЗАДНИЙ ТОРМОЗ Magura MT6, hydraulic disc, Hi Friction pad, alloy caliper, Storm SL rotor, 160mm rotor
ТОРМОЗНЫЕ РУЧКИ Magura MT6, carbon master cylinder, alloy lever blade, hollow lever pivot, reach adj.
ПЕРЕДНИЙ ПЕРЕКЛЮЧАТЕЛЬ SRAM X0, 10-speed, S3 direct mount for DMD, bottom-pull
ЗАДНИЙ ПЕРЕКЛЮЧАТЕЛЬ SRAM X0 Type 2, 10-speed, mid cage
МАНЕТКИ SRAM X0, 10-speed, twist
КАССЕТА SRAM PG-1050, 10-speed, 11-36
ЦЕПЬ KMC X10, nickel plate, reusable Missing Link
СИСТЕМА Custom SRAM carbon S-2200, 10-speed XC double, PF30 spindle, removable spider, S: 170mm, Others: 175mm
ЗВЁЗДЫ 38/24
КАРЕТКА SRAM PF30, OS press-in bearing, sealed cartridge
ОБОДА Roval Control Carbon 29, carbon disc, 27mm wide, 32h
ПЕРЕДНЯЯ ВТУЛКА Roval Control Carbon 29, OS28mm end caps, QR, 32h
ЗАДНЯЯ ВТУЛКА Roval Control Carbon 29 142+, DT Swiss alloy cassette body, 12mm thru-axle, 32h
СПИЦЫ DT Swiss Super Comp, 2.0/1.65/1.8 stainless
ПЕРЕДНЯЯ ПОКРЫШКА S-Works Fast Trak, 2Bliss Ready, 120 TPI, aramid bead, 29x2.0"
ЗАДНЯЯ ПОКРЫШКА Specialized Fast Trak Control, 2Bliss Ready, 60 TPI, aramid bead, 29x2.0"
КАМЕРЫ Ultralight presta
СЕДЛО Body Geometry Phenom Expert, hollow TI rails, 143mm
ПОДСЕДЕЛЬНЫЙ ШТЫРЬ Specialized 2014 butted alloy, single bolt setback, 30.9mm, 400mm
ЗАЖИМ ПОДСЕДЕЛЬНОГО ШТЫРЯ Specialized 7050 hard anodized alloy, 36.9mm, single bolt
Связь ЛС, тел. 896O1388658.
Последний раз редактировалось Anton_Grey 23 сен 2014, 16:30, всего редактировалось 5 раз.
Ваш код сегодняшний, коллега,
напоминает даунхилл,
среди деревьев и говнища
велосипед и костыли.
Re: Продаю Specialized Epic Marathon L (2013)
Все таки решился продавать , кому то повезет. Удачной регенерации.
Эм-м..., а-аа-а..., где ж, все вы раньше были...? :) Ну, типа..., поздно, блин, едет уже, на днях, уже вот-вот.
А так красавец, да.
Действительно кому-то повезет. :)
Phone: +7-908-137-52-97
Real Name: Максим
Сообщение Afer »
Ой как хорош, но сейчас на обновление велосипеда не рассчитываю.
KEEPER писал(а):де ж, все вы раньше были...?
он тебе велик , оно конечно тебе не привыкать ездить на велосипедах на 3 размера больше
Оффтоп, конечно, но уже второй эпик продается в связи с травмой владельца. Воронеж не принимает на энергетическом уровне?
Что ж такое случилось, чтобы прям велосипед продавать?
Я правильно понял, что верхние перья карбоновые, а нижние алюминиевые?
sparven писал(а):Что ж такое случилось, чтобы прям велосипед продавать?
Связки крестообразные порвал, еле хожу, жду второй операции.
sparven писал(а):Я правильно понял, что верхние перья карбоновые, а нижние алюминиевые?
Именно так.
все равно не понятно, зачем из-за травмы велик продавать. если только бабло нужно. К следующему сезону восстановишься.
Mazay писал(а):все равно не понятно, зачем из-за травмы велик продавать. если только бабло нужно. К следующему сезону восстановишься.
В следующем сезоне куплю новый :) А пока нужны деньги, стоимость лечения намного больше стоимости байка. По поводу востановления - это довольно оптимистичный прогноз.
Да, связки дорого лечить. Если правильно восстановлением заниматься, я думаю вполне реальный срок. Не 100% конечно восстановится, но уже хорошо должно быть.
My bike: trek 8500
Phone: +79066796389
Real Name: Nedjmdin
Сообщение nedjmdin »
где же Алексеин, или он ему великоват? он уж точно восстановился.
nedjmdin писал(а):где же Алексеин, или он ему великоват? он уж точно восстановился.
Где же хоть кто-то :) Добавил актуальные фото. Для форумцев скидки :good:
My bike: specialized epic
Phone: +79204364008
Сообщение Alexein64 »
великоват ищу М :Search:
