2021-09-11 - Бревет "Петушиный-200" (грунтовый)
Модераторы: Zheny, UNE
UNE
Phone: 95I-54з-з4-2з
Real Name: Юджин
Сообщение UNE »
Рандоннерский клуб "КБП-Курск" представляет:
Бревет 200 км "Петушиный"
Дата: 11 сентября 2021 (суббота)
Старт: Воронеж, кольцо на пересечении ул. Острогожской и ул. Матросова в направлении п. Шилово
Финиш: там же.
Норматив: 13,5 часов
Начало: 11.09.2021 в 06:00
Контрольное время: 11.09.2021 в 19:30
ПОЛОЖЕНИЕ О БРЕВЕТАХ (читать всем!!)
Форма для регистрации
[map]51.6349,39.17222 51.62569,39.17647 51.62119,39.17609 51.6085,39.17952 51.59584,39.17703 51.58747,39.17287 51.55551,39.09923 51.55445,39.09305 51.53779,39.07408 51.53651,39.07004 51.53795,39.04507 51.52792,39.03013 51.50815,39.00945 51.49613,39.01151 51.49079,39.01434 51.48897,39.01391 51.47508,39.02275 51.46345,39.01833 51.45013,39.02691 51.44026,39.02631 51.43419,39.03932 51.43044,39.04279 51.41342,39.04176 51.41149,39.04284 51.4067,39.04133 51.39947,39.04537 51.398,39.04455 51.39192,39.05163 51.38815,39.05301 51.38351,39.06095 51.37805,39.06635 51.36739,39.0724 51.36578,39.07167 51.36058,39.08073 51.35584,39.08176 51.34957,39.11841 51.34721,39.12038 51.34085,39.13764 51.33619,39.14738 51.32946,39.15643 51.32334,39.16111 51.30022,39.16806 51.29306,39.16836 51.28487,39.16609 51.28039,39.17072 51.26997,39.16055 51.26377,39.16111 51.26143,39.14806 51.25963,39.14648 51.2512,39.15094 51.24808,39.15017 51.24098,39.15257 51.23658,39.1604 51.22454,39.16789 51.22038,39.1678 51.21655,39.17017 51.21389,39.17345 51.20967,39.19557 51.19935,39.20765 51.19662,39.21448 51.19271,39.23634 51.18714,39.24531 51.17837,39.24679 51.1763,39.25222 51.17761,39.25979 51.16772,39.26269 51.16263,39.25934 51.15437,39.25818 51.14877,39.24758 51.14565,39.24625 51.14118,39.23952 51.13095,39.2296 51.12351,39.21875 51.11769,39.20802 51.11516,39.20063 51.11543,39.19596 51.11266,39.1936 51.11128,39.18926 51.11613,39.18377 51.10975,39.17094 51.11139,39.1572 51.10352,39.15128 51.10266,39.15394 51.10153,39.15184 51.09657,39.1557 51.08676,39.14613 51.08444,39.13467 51.08546,39.13377 51.08164,39.12708 51.07916,39.11485 51.06608,39.12081 51.05793,39.12163 51.05228,39.12538 51.04742,39.12573 51.04189,39.12287 51.03121,39.11002 51.03161,39.10412 51.02932,39.09989 51.02499,39.09897 51.01181,39.08944 51.01805,39.05146 51.01648,39.04258 51.02739,39.03408 51.01362,39.02962 51.00682,39.00694 51.01348,39.00895 51.01972,39.00604 51.02443,39.00567 51.02791,38.99307 51.0269,38.98784 51.04536,38.98164 51.05175,39.00052 51.04782,39.02138 51.04728,39.04593 51.05197,39.06961 51.05569,39.07176 51.06147,39.09528 51.0701,39.11845 51.07969,39.11433 51.08385,39.12995 51.09975,39.12875 51.10099,39.14901 51.10535,39.15665 51.10719,39.15347 51.1109,39.1612 51.1101,39.17089 51.12114,39.18737 51.12981,39.19235 51.16196,39.19596 51.18763,39.17999 51.19037,39.17536 51.19083,39.16673 51.19997,39.16673 51.20489,39.15918 51.21183,39.16107 51.21683,39.15476 51.22484,39.14909 51.22492,39.15351 51.24816,39.14888 51.25096,39.15137 51.25848,39.1454 51.26041,39.13669 51.28586,39.12858 51.29375,39.12094 51.32224,39.11133 51.33662,39.08421 51.33957,39.07039 51.33876,39.05906 51.34059,39.03751 51.34477,39.0361 51.35117,39.03108 51.36007,39.0367 51.36524,39.05365 51.368,39.05828 51.37802,39.06322 51.38255,39.06107 51.3878,39.05292 51.39457,39.04884 51.39851,39.04429 51.40692,39.04082 51.42252,39.04185 51.43065,39.04391 51.44063,39.02653 51.45117,39.0267 51.4601,39.02099 51.46703,39.01889 51.47815,39.02232 51.47935,39.02764 51.48924,39.03721 51.49653,39.037 51.49867,39.03932 51.50268,39.04983 51.51635,39.06228 51.5183,39.07734 51.52834,39.08352 51.53374,39.083 51.53875,39.07674 51.55287,39.09004 51.56371,39.11927 51.58704,39.17261 51.59683,39.17686 51.60965,39.17978 51.62025,39.17583 51.62598,39.17609 51.63491,39.17232(Козеяменский-200 on GPSies.com)[/map]
Козеяменский-200.gpx
(45.7 КБ) 417 скачиваний
Стартовый взнос 150 руб.
Маршрут без поддержки, с отметкой на КП.
Регистрация на старте с 5:45 до 06:00.
Форс-мажор
Бревет может быть перенесен в случае форс-мажорных обстоятельств.
Отметки
Отметки на КП (старте/финише)
Использование новой системы регистрации и контроля
В качестве основного и настоятельно рекомендуемого способа отметки на КП (старте/финише) используется вэб-версия приложения, доступная по адресу https://app.kbp-kursk.ru (для всех платформ и ОС). Описание работы системы.
Вопросы использования новой системы регистрации и контроля.
При отсутствии возможности использовать ПО, самоотметка возможна с помощью чеков из магазинов, фотографий старта, разворотной точки маршрута/точек КП и точки финиша(на фотографии должен быть виден велосипед или селфи на общем плане точки), так же в качестве отметок принимаются треки с маршрута при возможности посмотреть время нахождения бреветчика в ключевых точках маршрута.
В течение суток после завершения бревета участник должен предоставить данные приложения, или фотографии/трек. Не предоставившие результаты считаются не финишировавшими.
ВАЖНО!
Невозможность сделать отметку в приложении (зависания телефона, участника, случайное нажатие кнопки "Завершить бревет", и др.) не освобождает участника от необходимости делать отметки! Нужно отмечаться другим предусмотренным способом - фотографии, чеки (в т.ч. справки об операциях из интернет-банка), GPS-трек. Отсутствие отметки, или данных об отметке другим способом в течение 24 часов после бревета = отметка о сходе. Отметка вручную также должна сопровождаться предъявлением трека или иного доказательства пребывания на КП, особенно если она сделана из места, где была возможна срезка.
"Свидетельские показания" других участников не являются предусмотренным правилами способом отметки на КП.
Сход с маршрута
При сходе с маршрута обязательно уведомить ответственного! Чтобы вас не ждали на финише.
Эвакуация с маршрута возможна посредством рейсовых междугородних и местных автобусов, в основном в крупных населённых пунктах.
Про медали
За успешное участие в бревете можно заказать памятную медаль. Ее стоимость – 5 евро + страховка на случай скачков курса и оплата доставки медалей из Франции. Ориентировочно итоговая цена – 600 рублей. Заказ медали делается отметкой в стартовом протоколе. Деньги (в том числе за медаль) вносятся перед стартом, в случае схода с маршрута стоимость медали возвращается, регистрации — нет. После отправки протокола дозаказ медалей невозможен!
По поводу медалей с пятухом тут.
Рекомендуется иметь с собой запасную камеру, велоаптечку, насос, минимальный набор инструментов.
Шлем - настоятельная рекомендация.
Обязательно движение в темное время суток в светоотражающем жилете.
За не использование светоотражающего жилета в темное время суток — штраф 2 часа.
И самое важное – Ваша безопасность это целиком и полностью Ваша забота.
Берегите себя.
Ответственный за регистрацию: Евгений (UNE)
Тел. 895154зз42з
evgune@inbox.ru
ССЫЛКИ:
Сайт: http://www.kbp-kursk.ru/
Группа ВКонтакте: https://vk.com/kbpkursk
Форум: http://www.kbp-kursk.ru/forum/index.php
Группа в телеге: t.me/brevetvrn
Достопримечательности по маршруту:
Маршрут проходит вдоль р. Дон, и соответственно, это меловые холмы вдоль русла реки - визитная карточка Воронежской области.
Особо известные места - это село Сторожевое и село Титчиха, где расположены видовые места на уникальный природный ландшафт.
Музей-заповедник в с. Костёнки, где были обнаружены стоянки древнего человека.
UNE
Real Name: Юджин
Re: 2021-09-11 - Бревет "Петушиный-200" (грунтовый)
Сообщение UNE »
Как говаривал БэдАдмин: "Стартовый взнос в размере 150 (без медали) или 750 (с медалью) рублей можно перевести по номеру телефона +79515433423. Через Сбербанк или систему быстрых платежей (выбрать банк получателя "Сбербанк").
В сообщении получателю или смс указать фамилию-имя, или ник, или стартовый номер зарегистрированного участника!
Переводы без сообщения с реквизитами участника считаются подарками лично мне. Выяснять, за кого сделан перевод, я не буду. Аналогично, если перевод сделан за незарегистрированного участника.
Обратите внимание, что не все банки - участники СБП поддерживают передачу сообщения получателю, поэтому использование Сбербанка является предпочтительным.
Отметка о получении средств будет не в реальном времени, но относительно быстро появляться в списке зарегистрированных участников, напротив ника."
Дядя Женя, а как же рассказать про юбилейный бревет, уникальную мядальку и вот это вот всё?
Название несколько настораживает)) И чем вы там занимаетесь на этих ваших бревентах? Куда смотрит общественность :unknown:
Mitritch писал(а):И чем вы там занимаетесь на этих ваших бревентах?
Phone: 89o42I3I849
Real Name: Максим
Сообщение Umgerade »
От кьянти в яме я не откажусь. Mitritch, поехали, нельзя такой праздник пропускать.
P.S. Был уверен, что Женя ночной сделает. Но он похоже более человеколюбив, чем я думал. :D
UNE
Real Name: Юджин
Сообщение UNE »
11 сентября 2021 года 100-летие первого официального бревета на 200 км.
Посему, к этому бревету выпущена специальная юбилейная медаль. Единственный шанс ее получить - проехать этот бревет!
Гальский петух - символ свободолюбивой Франции, если шо :D .
В случае непогоды маршрут перенесётся на асфальт и завернёт на север.
На финише предлагаю совместно употребить алкоголя и углеводов.
За такой медалькой стоит съездить))
А я подумал, что Вован свои петухи будет раздавать))
Краем уха слышал, что будет какой-то спецучасток, но по треку вроде обычный Козеяменский.
А ночью на этом маршруте будет уныло без обзора красот, ну разве что по прохладцу торчки залезать хорошо.
My bike: Colnago Ramarro
Сообщение Bad_Admin »
Вы то объявление о бревете за неделю до старта вешаете, а потом удивляетесь, что никто не приехал, то впереди паровоза бежите, сообщая о медали, которую получит далеко не каждый.
Медаль-то юбилейная, вот только их ограниченное количество, и дозаказа не будет. Поэтому именно юбилейные медали достанутся только тем, кто более причастен.
Ссылку на метод определения причастности я давал Вовану, но он, видимо, не посчитал нужным сообщить об этом окружающим.
"Можно и нужно проводить юбилейный бревет в других городах.
Но с юбилейными медалями будут тонкости. Они уже у меня, но:
а) количество ограничено, и дозаказа не будет;
б) сразу после бревета, при определенных обстоятельствах, медали может быть будут раздаваться только в Курске. В 6 утра следующего дня у меня поезд в отпуск, так что я уже ничего не успею сделать с медалями для других городов (хотя могу завезти в Воронеж, при условии, что их заберут на вокзале у поезда).
Медалей много, больше, чем когда-либо заказывали за один бревет. Но тут юбилей, и медали в наличии. На случай ажиотажа подстраховываемся заранее.
Если желающих получить юбилейную медаль будет больше, чем медалей, то будут определенные правила, причем общие для всех стартов.
В случае, если по состоянию на 18:00 дня, предшествующего старту, зарегистрировавшихся и оплативших регистрацию и медаль участников будет больше, чем медалей, то распределяться медали будут согласно места в клубном рейтинге (сводная таблица сезона + архив всех сезонов. Т.е. достанутся тем, кто дольше и дальше рандоннер. Разумеется, при этом нужно успешно проехать бревет, причем именно 11 сентября, вне зависимости от погоды. Зарегистрировавшиеся после 18:00 пятницы перед стартом, в определении "кворума" не участвуют, и получат медали исключительно по остаточному принципу, вне зависимости от места в рейтинге."
http://www.kbp-kursk.ru/forum/viewtopic ... 9276#p9276
Ссылки, которые пропали при копировании
https://app.kbp-kursk.ru/season
https://app.kbp-kursk.ru/archive/all
Все предельно ясно, честно и обосновано.
Короче, как обычно ничто не помешает нам выпить))
Phone: 89o42I3I849
Real Name: Максим
Я после прошлой Кузиямы завалился в Брюггер и втарил бутылку Oude Geuze Boon Mariage Parfait. Отлично зашло. Ну а медальки... Ну коль не хватит на меня, переживу. Главное процесс.
UNE
Real Name: Юджин
Сообщение UNE »
В четверг вечером напишу тут каким макаром поедем. А то может раскиснет всё к субботе.
Кто вписывается на послебреветный банкет?
Зайка
Сообщение wowanbezbash »
UNE писал(а):В четверг вечером напишу тут каким макаром поедем. А то может раскиснет всё к субботе.
я
My bike: trek 8500
Phone: +79066796389
Real Name: Nedjmdin
Сообщение nedjmdin »
По банкету нужна определенность
UNE писал(а):Кто вписывается на послебреветный банкет?
+1 если не опоздал
Надеюсь менять маршрут не придется
Real Name: Лена
Сообщение tzipik »
А, можно, банкет без 200 км? 8)
My bike: trek 8500
Phone: +79066796389
Real Name: Nedjmdin
Можно без 200, ты же самочка)))
Phone: 89o42I3I849
Real Name: Максим
UNE, а где пройдет банкет?
Погода хорошая будет, никаких дождей.
My bike: trek 8500
Phone: +79066796389
Real Name: Nedjmdin
у меня. надо знать состав заранее. Больных не пущаю
Уне, безбаш, принцесса, митрич и я
Кто еще будет, подайте сигнал.
