Продам прыжковый велосипед Specialized P.3 2007
My bike: Kona, Specialized
Сообщение _Insane_ »
Состояние нового, катался один год, потом стоял на балконе прикрытый простыней.
Телефон: +79202133056
Цена: 21000 руб
Ростовка: L. Брал для себя, рост 183 см
http://www.bikepedia.com/QuickBike/Bike ... &Type=bike
Руль Specialized OS Freeride, 680mm wide, 53mm rise, 8 degree back, 6 degree upsweep
Передний тормоз Avid Juicy 3, hydraulic disc, 6" G2 Clean Sweep rotor
Задний тормоз Avid Juicy 3, hydraulic disc, 6" G2 Clean Sweep rotor
Вилка Marzocchi DJ 3 SL Urban, 100mm, 32mm alloy stanchions and 1 1 /8" steerer, coil spring w / air assist, rebound adjustment, bolt on forged crown, magnesium lowers, 20mm through axle dropout
Задний переключатель SRAM X-9, short cage
Манетки SRAM SX-7 9-speed trigger
Обода Specialized /Alex P.Disc 26 double wall disc w / eyelets
вынос Truvativ Holtzfeler, forged alloy, 31.8mm, 0 degree rise
педали Specialized Lo-Pro Mag II, cartridge bearings, magnesium body, 9 /16"
седло Fuse SL, kevlar nose and tail, non slip sides and hollow 9mm Cro-Mo rails
рама A1 Premium Aluminum, double butted ORE DT and TT, forged /releived HT and ISCG BB, 6mm offset rear triangle and forged horizontal drop-outs w / integrated chain tensioners, replaceable hanger
грипсы Specialized Micro flange, Kraton w / CNC alloy bar end plug
тормозные ручки Avid Juicy 3 hydraulic
цепь SRAM PC-951, 1 /2" x 3 /32" w / Power Link
шатуны Specialized Fuse SL, 175mm length, heat treated Sanko Cro-Mo tubular arms, hollow 19mm Cro-Mo spindle, for 52mm chainline; 32A w / ISCG mounted E.13 "32 Special" chain guide
каретка Fuse SL Euro, for 2pc crank, alloy cups, 4x cartridge bearings, alloy tube spacer, 6x steel outside adjust spacer, 1pc chainring bolt
передняя втулка Specialized Hi Lo 20mm, CNC flange and disc mount, 36h, for 20mm thru-axle
задняя втулка Specialized 10mm through axle cartridge cassette, CNC flanges and disc mount, 36h
спицы 2.0mm (14g) stainless black
передняя покрышка Specialized Rhythm Pro, 26x2.3", DC, 60TPI, aramid bead
задняя покрышка Specialized Compound Pro, 26x2.2", DC, 60TPI, aramid bead
подседельный штырь Fuse SL, dual bolt, 30.9mm
Последний раз редактировалось _Insane_ 18 май 2013, 00:11, всего редактировалось 4 раза.
Re: Продам прыжковый велосипед Specialized P.3 2007
Лишнее удалено.
GraduSу персональная благодарность за определение модели, а то ТС, за давностью лет, забыл как точно называется продаваемый им велосипед.
_Insane_
Добавьте в тему, в первое сообщение, размер рамы продаваемого велосипеда
